sickle mower
maestro
05-20-2007 17:34:53
I recently purchased an allis chalmers sickle mower at a sale and I know nothing about it. I can"t find a model or seriel number on it anywhere. It is a trailing mower and has a 9" bar. Nice shape and appears to be fairly new. Please help! Model, seriel number anything will be a great help. Thanks, Maestro
JMS/MN
05-21-2007 07:51:27
 Re: sickle mower in reply to maestro, 05-20-2007 17:34:53
By 'trailing'- you mean having its own two wheels and connected to the tractor with a single hitch pin in the drawbar- the Model 80T was available in 1960, and had the Twin Wheel drive pioneered by the No. 7 in 1956. Model 82 series came out in 1965. 82 would have a white background on the decal on the frame. 80/82 had the option to run a conditioner hooked behind.
maestro
05-21-2007 08:08:00
 Re: sickle mower in reply to JMS/MN, 05-21-2007 07:51:27
Yes it has 2 wheels on the back and is pulled by one single pin to the tractor. It does have a white back ground decal with black letters that say Allis Chamlers. Do you know where I can get a manual? Anymore information would be greatly apprecaited. Thanks, Maestro
Eldon (WA)
05-21-2007 10:47:12
 Re: sickle mower in reply to maestro, 05-21-2007 08:08:00
If it has the little 8" tires it is an 80T, if it has larger tires (14" I believe), it is an 82T. These manuals come up on Ebay from time to time.
Skyhighballoon(MO)
05-21-2007 13:52:18
 Re: sickle mower in reply to Eldon (WA), 05-21-2007 10:47:12
Eldon - the #7 trailer mower had the little tires. 80T has 14 inch tires on 4 bolt rims with a straight line wheel arangement. 82T had staggered wheels I belive. Mike
Skyhighballoon(MO)
05-21-2007 13:52:18
Eldon (WA)
05-21-2007 15:59:38
 Re: sickle mower in reply to Skyhighballoon(MO), 05-21-2007 13:52:18
Mike you're right....that's what I get for trusting my memory.....shoulda took the time to look it up.
JMS/MN
05-21-2007 08:32:49
I found an Op/Setup manual at an AC show. Tractor manuals have many current sources but equipment manuals are harder to find. I have a seven foot 82S on a WD45, also mounts on the D-Series. Don't know about the nine foot options, but do remember a short-line mfr like Kosch that had them around 1960, on a mower that mounted on a WD.
Kent of SWMO
05-21-2007 06:09:57
Is this a pitmanless mower? If so the model number varied depending on whether it is a pull behind, rear mount three point or belly mount but they were called a TWIN WHEEL mower.
Kent
maestro
05-21-2007 08:00:01
 Re: sickle mower in reply to Kent of SWMO, 05-21-2007 06:09:57
It has two wheels and is a trailing mower. The decal is white with black lettering if that helps any. I don"t believe it has a pitman. Where can I get a manual? Anything else you can help me with? I greatly appreciate your help.
