no start after setting overnight
genetexas
05-20-2007 06:57:24
I have aquired a 1982 AC6140 and it will not start after setting for a period of time. I have had the fuel pump rebuit but still won't start without starting fluid. any help will be greatly appreciated.
Texas Denny
05-20-2007 07:31:59
 Re: no start after setting overnight in reply to genetexas, 05-20-2007 06:57:24
It could be lots of things. But the most probable is a bad choke, poor compression or bad spark plugs. I've experienced both of the last two. If the rings or worn out or the valves don't seat properly, low compression will make starting difficult.
I've had hard starters that improved significantly with a new set of plugs.
The third thing is the choke. Does the 6140 have an automatic choke? If it does, it might not be opening and closing properly. Might not be a problem when warm but impossible when completely cold. If it doesn't have an automatic choke, make sure the manual choke is working correctly.
Actually, if you bought it to use, ether is a lot cheaper than an overhaul. You could probably have the same success with an empty Windex bottle filled with gasoline. Usually a shot of gas in the carb will work also.
