Allis Chalmers serial numbers
Robert Dellutri
05-19-2007 05:35:07
I am having one heck of a time trying to determine the year of the tractor that I just purchased. I was told that it is a 1948 Allis Chalmers B model but can't match up the serial numbers that are on the tractor... HELP!
Serial Numbers as follows:
Top behind gear shifter.. 280600
Top in front of shifter.. C14664
Side... 3284
Left side of gear box..L-13-RL
Bill of Sale.. AM 2961-23
I need to replace the "Hydraulic Lever" but have no idea where to purchase the correct lever for this tractor.
Any help will be truly appreciated!
steve(ill)
05-19-2007 06:22:40
 Re: Allis Chalmers serial numbers in reply to Robert Dellutri, 05-19-2007 05:35:07
dont use cast numbers. the stamped number C14664 is the tractor number. it is a model C serial number 14664. check the sn page, it will be an early 1942-3 probably. probably narrow front end, 15 inch front tires, 24 inch rear wheels, no tractor frame, motor is mounted to a torque tube with 4 studs and trans mission mounded on the other end same way. has a 125 inch 4 cyl motor, about 20 HP, 3 speed. can have belt and sahft ptos and hydraulics is small, but lots of pressure.
Gatz
05-19-2007 05:47:32
Robert, check out Bryan Smith's web page
...on right column, about 3/4 down for Serial Number Location Images.
Should be able to use the other topic pages to determine year of mfg.
If not, I have a book that shows S/Ns; shoot me an email
Gatz
