WD/WD45
Pete Koehler
05-17-2007 19:06:27
Could anybody tell me if during the transition from WD to WD45, there could be motors not stamped with a 45 in the serial no.,and also not having the bolt on cover on the right side of motor. Also is the only giveaway for a WD transmission and rearend the straight gear shifter? Thanks fellas in advance
old
05-17-2007 21:04:57
 Re: WD/WD45 in reply to Pete Koehler, 05-17-2007 19:06:27
ALL WD tractors have engine with bolt on plates if still stock. A WD45 engine will not havre the bolt on plate. Some of the late WDs hjad the curved shifter which was also the WD45 tranny.
Texas Denny
05-17-2007 20:59:56
All WD-45 tractors were plateless. All WD engines had plates. Some of the last WD tractors had WD-45 transmissions because Allis didn't make the right quantity to match the engines they'd built. So some late WD's do have the curved shift.
