g--stuck,almostt
jpl
05-17-2007 17:01:54
my friend has a g and had it rebuilt, new pistons etc. ever since then it wont start with starter unless you pull it, i beleive i read something about shims behind harmonic balancer causing the problem when you snug it up. i am going to check it out. he thinks its high compression, but i dont beleive thats the problem. any help appreciated. reputable machine shop did the rebuild but dont think they know that much about a g eng.
jpl
05-17-2007 21:38:55
 Re: g--stuck,almostt in reply to jpl, 05-17-2007 17:01:54
thanks for the info, he is going to bring it over in few days and i;ll check it out. i;ll post later after i find the problem. have a good day.
jpl
05-17-2007 18:08:12
has 6 volt battery with the 6 volt cables, the motor turns very hard like its bound up. read somewhere about wrong shims behind the pully.
Dick L
05-17-2007 19:18:53
 Re: g--stuck,almostt in reply to jpl, 05-17-2007 18:08:12
You would need to pull the crankshaft timing gear off and remove shims from behind the gear to free it up if that is your problem. The crankshaft pulley bottoms out on the end of the crankshaft and pushes the timing gear tight against the shims. That in turn tightens the tolerance on the thrust washers. You could cut a small .002 shim to place in the bottom of the crankshaft pulley and see if that would relieve the pressure from the thrust washers. If it helped it would save taking the timing cover off.
That little 9 horse engine does not turn over hard when everything is new with the correct tolerances.
El Toro
05-17-2007 18:43:27
If the shims don't make the starting any easier you make need to take a look at the rod and main bearings and plasti-gage them. They may have the clearances too tight. Hal
El Toro
05-17-2007 17:49:59
If this tractor still has the 6 volt system it should have 00 copper battery cables. Hal
