WD 45 Info Needed.
JDGnut
10-05-1999 19:59:26
What is the drawbar HP of a WD 45? what is the pto hp? Is the engine in a WD the same except for the stroke in a WD 45. And what is the factory stroke and bore for the WD 45. Thanks for the info.
JDGnut
Chip
10-06-1999 20:03:42
 Re: WD 45 Info Needed. in reply to JDGnut, 10-05-1999 19:59:26
I assume you're talking gas burner. Drawbar: 37.84. PTO: 43.21. The block of a WD45 is basically the same as a 45, but the engine has higher compression than a WD. The stroke of that 226 cube engine is 4.5" and the bore was still 4". We put D-17 sleeves and pistons, manifold and governor spring on ours and we're well over 50 horse with gobs of backup torque. Hope this helps
JDGnut
10-07-1999 09:21:11
 Re: Re: WD 45 Info Needed. in reply to Chip, 10-06-1999 20:03:42
Thanks for the info, Chip.
