Plowing with WD
Brio Bean
05-17-2007 05:03:38
I plowed about 3 acres of winter rye with my 3 bottom WD plow. It worked ok but not perfect. Then I started plowing some sod and the plow just won't work right. Sometimes it turns the furrow but repeatedly plugs up. The grass is very short but the sod seems tough. Does anyone have any suggestions how I should adjust the plow to work in the sod?
Hoenes
05-18-2007 18:39:51
 Re: Plowing with WD in reply to Brio Bean, 05-17-2007 05:03:38
My son and I, have the same problem when plowing our deer food plot. Unless you plow 100 acres to get the plow to look like a mirror, it's going to stick. Might try a wire wheel on a grinder, and some gun grease.
