WC engine swap
K. Farmer
05-16-2007 20:58:53
does anyone know, is it the GM 292 that will fit in a AC WC without major mods? i bought a WC with a pretty beat up engine and missing many parts and i also found a 292 that i can get a hold of. My grandpa said there was a GM motor that was interchangable in that tractor and i thought that i heard that it was that motor.
thanks for any help
L Hud
05-19-2007 04:33:38
 Re: WC engine swap in reply to K. Farmer, 05-16-2007 20:58:53
The 292 will fit into the WC frame. Will have to make two adapters. One for the engine to bellhousing and one for the flywheel. The radiator will have to be moved to the end of the frame like a 45 diesel. I have a WD with a 292 on it. Hope this helps.
John (MO)
05-18-2007 05:40:47
With money and time almost anything can be done. In this case you"ll need a fair amount of both. I think I`ve seen everything from 327 Chevys to 440 Mopars stuck in AC tractors, so undoubtedly there is no reason you couldn`t get a 292 in there. The question might be why. Seems like if you are going to go to that much trouble, you might as well kick it up another notch and drop in a V8. Otherwise when it`s all done, you`ll slap your forehead and say "I coulda had a V8".
K. Farmer
05-17-2007 20:35:28
I know that it will need some mods including longer frame rails, longer hood, etc. I was just wondering if it is possible to fit it in.
thanks
dej(jed)
05-17-2007 04:43:21
Just off the top of my head, I wouldn't think that a 292 would go in to a WC easily. It is quite a bit longer, so frame rails etc, would need to be longer. Bell housing etc. would be totally different too. I have an F12 with a 292, but it is a major retooled machine.
