WD45 distributer question?
Hossman
05-16-2007 17:43:26
Fellas, was wonderin can I pull the dist. assembly to check advance wieghts with out messin up the timing, if I drop it right back in place?Or will this require me to retime the tractor? thanks Hoss
Hossman
05-17-2007 15:44:32
 Re: WD45 distributer question? in reply to Hossman, 05-16-2007 17:43:26
Fellas, Thanks so much for the advice. I always like to check on things that Im not real familiar with before tearin into them and have not pulled dist. assembly before, again thanks alot, Hoss
John T
05-17-2007 09:17:31
Hoss, you ought to be able to mark where the distributor sits/mounts into the tractor as suggested below and with the cap off observe and mark EXACTLY where the rotor tip is pointed so when you replace the distributor its in the same exact spot as before. Dont turn the engine or it messes things up Welllll l DUH
The advance mechanism ought to allow you to turn the rotor somewhat against slight spring pressure but it should return back to the original location when released if alls well in the weight and spring area. If the advance is working properly a timing light should show the advance steadily as RPM increases.
NOTE: Im NOT any AC expert, the above is just generic so trust others before me regarding specific to AC questions.
John T
patsublett
05-16-2007 18:58:14
Mark it before you pull it out
