wd engine clutch replacement 6 or 9 spring?
orange-1
05-16-2007 07:55:50
Heres the question, will the upgraded 9-spring replacment clutch fit my 49 wd without any modifications? I researched clutch postings and found one that indicated modifications were required (bearing sleeve or something). The tractor will be used for finish mowing and snow removal. Last question, the tractor is a 49 wd with a wd45 engine...Do I even need the 9 spring upgrade??? Thanks,
BushogPapa
05-16-2007 08:28:23
 Re: wd engine clutch replacement 6 or 9 spring? in reply to orange-1, 05-16-2007 07:55:50
The 9 spring clutch is exactly the same, only with 3 more springs...use it...!!!
You won't feel any difference at the clutch petal...
Ron.
