WD45 Hand Clutch Lever Stop ???
MikeRW
05-16-2007 05:43:21
There is a handl clutch lever stop on ebay. My WD45 doesn't have one. Was this an option or is mine missing. Does this stop the hand clutch lever from extending forward farther than need be or is there another purpose? Thanks.
Rene In.
05-17-2007 16:29:50
 Re: WD45 Hand Clutch Lever Stop ??? in reply to MikeRW, 05-16-2007 05:43:21
Eldon is correct
wilman
05-16-2007 13:12:05
Eldon is correct.
Wil
Sid
05-16-2007 08:01:13
The linkage rod on my WD can be adjusted to determine how far forward the lever will go. I ain't saying it is and I ain't saying it ain't, I have never seen anything like that on any WD or any WD45. It is not in my parts section of my owners manual. I suspect it is after market or perhaps home made. I can see how it would work and in my opinion it is a nifty little idea.
Eldon (WA)
05-16-2007 06:50:57
I believe they were part of the "plow safety release" package. This would kick out the hand clutch if the plow caught a rock or tree root. When this happened the hand clutch would be forced forward a lot harder than you would typically release it by hand, so my guess is AC thought they needed to cushion it somewhat. You shouldn't need it unless you have the safety release and plow in rocky ground.
JMS/MN
05-17-2007 11:30:43
 Re: WD45 Hand Clutch Lever Stop ??? in reply to Eldon (WA), 05-16-2007 06:50:57
This is new to me. I've seen many WD tractors with the throwout connection to the spring on the drawbar/hydraulic connection- but never saw anything that would catch or cushion the forward throw of the hand clutch. Is that what you are talking about? After all, after the clutch was thrown forward, disengaging it- what was the need to 'catch' it?
