Replace or not replace...Oil Pump wd45
orange-1
05-15-2007 12:20:05
I'm in the process of a total engine overhaul on my wd45. New cam bushings, grinding & polishing crank, re-sizing rods, pistions, sleeves, etc. My question is...should I replace the oil pump? The oil pressure was very low (non-existent) actually spun rod bearing prior to tear down. Is there anyway to verify the condition of my oil pump prior to installation?
Thanks,
old
05-15-2007 17:53:55
 Re: Replace or not replace...Oil Pump wd45 in reply to orange-1, 05-15-2007 12:20:05
My self if I rebuild the engine I always either rebuild the oil pump or replace it. Why spend all that $$ on a rebuild and then not replace the one thing that will cause one to blow up fast if its bad
GaryH mi up
05-15-2007 14:39:32
If it were me I'd check your clearences ,your old pump may need some machine work such as the end plate surfaced .I'd bet your low oil pressure was because your engine had probably been "rebuilt" many times without having the cam bearings replaced.
