Allis CA Brake Springs
Mike in Carolin
05-14-2007 20:13:00
I recently bought an Allis CA as a restoration project. In replacing the brake bands I found that both brake return springs were broken at the end opposite the adjusting screw. Where do they attach? Thanks!
Jim Craig
05-15-2007 05:41:08
 Re: Allis CA Brake Springs in reply to Mike in Carolina, 05-14-2007 20:13:00
They attach to the top of the adjusting screw/bolt and the lower end goes through a hole in the casting. Tip: Place spring over screw head and then attach a wire to the other end and pull your spring into place via the wire with a wrench or screwdriver for a handle to pull the wire.
Mike in Carolina
05-15-2007 11:26:55
 Re: Allis CA Brake Springs in reply to Jim Craig, 05-15-2007 05:41:08
Thanks Jim. The tip to stretch them into place was very helpful.
