WD gas problem
Larry Kabe
05-14-2007 06:05:15
I have a 1951 WD that after running for 10-15 min starts to die out due to a lack of gas. I have good gas floe to the carb. but I have to chock it to keep it running after the tractor is warm. I took the carb. apart and it seems to be in very good condition. Could this be a problem with the intake gaskets? The motor was rebuilt only a short time ago.
Larry Kabe
05-15-2007 05:23:27
 Re: WD gas problem in reply to Larry Kabe, 05-14-2007 06:05:15
Thanks to all who responded, I found the problem to be a bad gas line. Someone in the past replaced part of the steel line with rubber and the inside of the line was rotten restricting the gas flow at times.
Thanks again
Larry
hd6g tmo
05-14-2007 14:50:52
Larry I had the same prob with a B. ran ok till it warmed up, then had to pull the choke 1/2 way to keep it running. replaced the intake gasket and it now runs fine.
terry palmer
05-14-2007 14:41:58
My 45 acted the same way. I ended up narrowing it down to the carb. I put my compresser to the gas intake and opened it for a second. What ever it was it was gone.
Wicksfield
05-14-2007 13:15:42
I had a problem with my tractor when dirt in the tank would clog the inlet of the sediment bowl. No good way to remove the dirt. So, I rolled a piece of house screen about 3 inches long and inserted it into the inlet of the bowl. Works great and to heck with the dirt in the tank.
Dave Grubb
05-14-2007 10:16:55
I think Denny is probably correct in that you have foreign material in the tank getting over the sediment bowl housing inlet. Is your fuel tank cap vented and is the vent open? That will stop fuel flow after running awhile. If you have foreign material it would be best to siphon it all out.
old
05-14-2007 08:05:57
Pull the main jet assembly out of the carb, turn on the gas. If you get a good steady flow there then you may also have a problem with the spark, ya it sounds funny but its true if you have a weak spark chokeing it helps because a richer mixture burns easier then a lean mixture does.
Texas Denny
05-14-2007 06:18:57
Sounds to me like some of the passages inside the carb are partially clogged. They are easily clogged and hard to clean. To function properly, they must be free of restriction.
The other possibility is still the tank. You see good flow when you check but there could be crude floating around in there that clogs up the input to the settling bowl. This stuff is not easy to remove. I had a WD once that I put a stand pipe in the settling bowl so it would draw gas from 2" from the bottom of the tank. That solved my problem.
