AC IB Clutch Noise
Rimshot
05-12-2007 10:49:25
A friend of mine has alittle IB. When you let the clutch out there is a noise---kinda whiny-not a growl. When you push the clutch back in it goes away. What is it? I thought maybe the throw-out bearing--if not that what could it be? Thanks
chalmersbob
05-13-2007 17:09:49
 Re: AC IB Clutch Noise in reply to Rimshot, 05-12-2007 10:49:25
sounds like noise coming from the trany. if it were the throwout bearing it would make the noise when the clutch is depressed. Bob
steve(ill)
05-12-2007 18:08:04
crawl under the tractor and look up thru the egg shaped hole. there is a grease zerm on the bearing-- put 4-5 shots in that and see what happens.
