refilling hyd lift cylinder
terry palmer
05-11-2007 13:30:48
I finally found lift cylinders for my wd45. Now how do I refill them and bleed out the air? Do I losen the large nut were the rod comes out? Are there any other things I should do first?
terry palmer
05-14-2007 14:47:11
 Re: refilling hyd lift cylinder in reply to terry palmer, 05-11-2007 13:30:48
Worked great and alot easier than taking them off. Now they will not stay in one position floats up and down. It picks up my rototiller no sweat it just will not hold in one place. If I have the control all the way down slowly it will creap up. Suggestions?
terry palmer
05-12-2007 07:22:23
thanks alot. todays project.
old
05-11-2007 15:04:12
Just hook them up and use them after 3 or 4 times of lifting and lowering they will have bled all the air out on there own
Aaron SEIA
05-11-2007 14:43:00
Easiest way is just hook it all up and let it pump up and down a few times. Eventually the air will all bleed out. If you hook the hyd hose up with the cylinder retracted (short), then most of the air will be out anyway.
Aaron SEIA
