1950 Allis Chalmers B Tractor
DDBETH
05-10-2007 17:16:22
When I put the tractor in gear and let out on the clutch nothing happens, what is my problem?
Any help is appreciated. Thanks
steve(ill)
05-10-2007 18:44:24
 Re: 1950 Allis Chalmers B Tractor in reply to DDBETH, 05-10-2007 17:16:22
engage the pto lever, then let the clutch out. does the top shaft turn? (the pto). if it does, then the clultch is good. if it does not turn, then the clutch or driveshaft is not connected. you may have sheard the pin on the shaft and it fell off the transmission or pulled out of the clutch... lay under the tractor and look up thru the egg shaped hole under the clutch and see what is going on that end. have someone push the pedal and watch.---- does the shift lever feel like it goes into gear?
old
05-10-2007 17:22:56
Could be a number of things wrong. Clutch could be bad. You could have a bad shifter and its not putting it in gear. You could have something broken in the tranny.
