b block
Lee Cramsey
05-08-2007 22:32:13
Does anyone have a good B block for sale near Illinois. TIA
Lee
old
05-09-2007 08:39:16
 Re: b block in reply to Lee Cramsey, 05-08-2007 22:32:13
I have 2 of them, both out of Cs but there the same as a B. ONe still runs good other then it need a sleeve in #2 because the sleeve thats in it has been plained so it will not seal like it should when you put a head gasket on it. MO kicker is closer to you then I am I'm at the lake of the ozarks in Missouri. E-mail is open
mokicker
05-09-2007 05:24:00
I have a C with the 125 engine that I am redoing. The engine was frozen due to bent rod. I was going to rebuild it; but, the crank needed to be built up and then remachined. Brother found me another engine cheaper than I can redo block. As far as I can tell, the block is fine, head is questionable. Have all pistons, cam, etc. Drop me a line if interested with a reasonable offer. I am in Fairview Hgts, Il just outside St Louis and close to Belleville Il. Email is [email protected]
