WD and plow
old
05-08-2007 09:05:05
Which one will it handle better?? I have a 2-12, a 2-14 and a 2-16 plow and want to know which a WD will handle better. The soil is heavy black dirt/clay and is in fesque sod
Thanks
Dick L
05-08-2007 19:30:29
 Re: WD and plow in reply to old, 05-08-2007 09:05:05
When I was in high school and a while after Dad had an oliver 77 which we pulled a 2-16 Oliver plow. We pulled a 2 -14 with an Oliver 66. Also had an Oliver 55 with 3 -14. In the fall when the ground was dry we would drop one bottom off the mounted plow on the 55. The other two tractors did not have any problems pulling the plows. In the spring plowing down big clover for corn the 2 -16 did a better job in covering sod than the 14 in bottoms. Dad had the yetter colters on all his plows. The WD would be about the same as the 77 and should handle the 2 -16 plow with ease if the tractor engine is up to snuff.
El Toro
05-08-2007 15:59:15
I would try the 14-inch and see how the tractor handles that. If you're plowing in hilly fields
it may slip some. Hal
old
05-08-2007 17:50:47
 Re: WD and plow in reply to El Toro, 05-08-2007 15:59:15
This is a small area on flat ground. I'm just doing about 1/4-1/2 acre or so. I plan on planting corn there. The 2-14 trip plow I have is a JD and the other 2 are both Olivers. Sure wish I had a corn planter for the tractor but I don't so I'll be useing a push type one row planter.
El Toro
05-09-2007 03:57:29
 Re: WD and plow in reply to old, 05-08-2007 17:50:47
I had a Farmall A with the 16-inch plow and it did
a fine job plowing about the same size area. Your AC should pull the 16-inch 2-bottom without any problem. It may make it dig a little if its in sod. I didn't have the rear tires loaded with calcium and the A slipped some in sod. Hal
