WD45 diesel smokes real bad!
MT. Trouble
05-07-2007 22:45:59
I recently bought a WD45 diesel. It billows white smoke when cold. When it gets warmed up it is better but still very excessive. I tested the nozzles and they seem ok. I checked the injection pump timing and it was right on. I advanced the timing about 1/8 inch and it seemed to smoke a little less. The tractor seems to have very good power but I notice there is almost no typical diesel engine "rattle" is this normal? I am considering advancing the timing a bit more to see if it continues to lessen the smoke. I also read in the service manual about "energy cells" in this engine, could these possibly be the problem? Any help would be greatly appreciated. Thanks, Dan. (The smoke does keep the mosquitos at bay!)
Collin john
05-11-2007 14:09:33
 Re: WD45 diesel smokes real bad! in reply to MT. Trouble, 05-07-2007 22:45:59
I purchased wd45 diesel about ten years ago and it acted the same as you describe. I ended up exchanging the injection pump out and having the injectors gone through, after that I could not make it smoke unless under a very hard load also the tractor was much stronger at low rpms.Hope you get lucky and do not need to do this but in my case it was worth the money, it has been a good tractor.If I remember right I spent around $800.00 back then. You might try just going through the injectors first, much cheaper. Good luck.
MT. Trouble
05-08-2007 18:08:28
Hey thanks alot for all the help, I think I will try advancing the timing a bit more. The guy I bought it from said he had the injector pump gone through a decade ago and it has smoked ever since, maybe the marks are off from where they should be. Thanks again! Dan.
JOHN HARMON
05-08-2007 18:05:42
My 1957 WD45 Diesel acted the same as you Posted from the day I saw it first until the day I sold it. It's the nature of a "Buda" Engine. Never lacked for power but two different occasions the Head had to be replaced as Hired help would pull the engine down to see it smoke and the Heat build up would cause a crack to begin around # 3 and #6 Pistons which soon developed into a leaky Engine and required a Head replacement. The WD45 soon went away to make room for a D17 Gas which was a top Tractor in my operation until I got a 190 gas for the heavy work.No more AC Diesel's for me.
Dick L
05-08-2007 10:53:03
I would play with the timing more. My Ford 961 smoked real bad whiteish color after it was warmed up. I checked the timing and it was right on. It was the first Ford diesel I owned and so I called a tractor jocky and he told me to just change the timing where it didnt smoke. It is hard on pump shaft seals so I have had the pump out a few times over the years and always line up the pump timing marks before pulling it out and forget about looking at the flywheel and have not had the problem return. It starts good. If the actual timing is off much they will be hard starting on not start at all.
CWL
05-08-2007 08:58:48
Makes me think of an L gleaner that I used to run. From a distance you could see a steady plum of smoke when it was operating. Didn't use an excessive amount of oil and was fairly easy on diesel. Could be the nature of a Allis diesel. I was also around a MF combine (750 I think) with a Perkins. That thing smoked like crazy until it warmed up.
Texas Denny
05-08-2007 07:27:47
I've got a D-17 diesel. It smokes like crazy when it is first started as well. Once it warms up, the smoke reduces. If you are in a confined area like a shed, the fumes will drive you out anytime but really, really quickly right after starting cold.
I always assumed it was the nature of the beast. I never made an adjustment because my D-17 has an amazing amount of power and accelerates like a finely tuned gas engine.
I give you all of this information because the two engines are much alike.
MT. Trouble
05-08-2007 07:41:47
 Re: WD45 diesel smokes real bad! in reply to Texas Denny, 05-08-2007 07:27:47
Does your engine sound like a typical diesel as far as rattle noise? Does yours continue to smoke when warmed up? Thanks again for the reply.
Texas Denny
05-08-2007 08:25:40
 Re: WD45 diesel smokes real bad! in reply to MT. Trouble, 05-08-2007 07:41:47
No, it doesn't make a lot of rattle like those Ford V8 diesels. Engine noise is not much different than a gas but the noise is different. Smoke reduces dramatically when warm. On a clear day, you can't see it much unless under heavy load - then the color becomes darker. On a cloudy day, it is visible but isn't excessive.
