WD carburetor rebuild kit
Rendall Gray
05-07-2007 17:10:20
The WD won't run long enough to get it off the trailer. Decided to overhaul the carb as it seems to run out of gas after a few seconds.
Pulled carb and the Marvel-Shembler number is TXS151. The block number is AM 3853-14 with a 4 on second line.
All I see for rebuild kits are TSX154 or TSX159. Can not even find any reference to a 151 on Google. Do all these models of carbs use the same kits?
Glen in TX
05-07-2007 18:48:36
 Re: WD carburetor rebuild kit in reply to Rendall Gray, 05-07-2007 17:10:20
MS book only shows your TSX-151 fitting Continental F124 and some 200 series Continentals also. If the carb works someone just probably substituted it sometime. Anyway MS book shows carb K7505 kit fits your TSX-151 and TSX-154 & 159 and many other TSX carbs use the same kit. Any NAPA, tractor supply or local Zenith Marvel dealer should have it in stock. zenithfuelsystems.com
Rendall Gray
05-07-2007 17:35:19
Of course it is a Marvel-Schebler.
Rendall Gray
05-07-2007 17:21:23
Typo!! My unit is a TSX 151.
old
05-07-2007 18:48:21
 Re: WD carburetor rebuild kit in reply to Rendall Gray, 05-07-2007 17:21:23
Most likely if it bolts right up then you could use the kit for the TSX154 on it. M-S had like 3 or 4 differant size carbs and they made kits to fit each size of carb.
