Gaskets for a WD
Chad B. Allis
05-07-2007 14:08:33
Does an aftermarket standard set of gaskets for a 1950 WD include a gasket for the PTO housing? (I call it the PTO housing - it's where the PTO shaft enters the differenetial - about mid-tractor). Mine leaks pretty good and I think a new gasket would do the trick. Can I just use some "cut it yourself" gasket? Can I get the gaskets anywhere?
Thanks!
old
05-07-2007 15:24:24
 Re: Gaskets for a WD in reply to Chad B. Allis, 05-07-2007 14:08:33
Have you tried an AGCO dealer?? That would be the first place I would look if you haven't
RENE' S,
05-07-2007 15:33:57
 Re: Gaskets for a WD in reply to old, 05-07-2007 15:24:24
STANDARD PTO GASKETS FROM TRUCK TRAN WILL FIT,
