Removing the Drawbar from a 39 B
Proud B owner
05-07-2007 06:40:14
I'm trying to figure out how to remove the drawbar from my 39 B. In order to get the plow on I think the drawbar will need to come off. I was hoping somebody could help my with how to do it and then also how to put it back on when I'm done plowing. Also if the drawbar doesn't need to come off could someone tell me how to position it to make it work.
D13
05-07-2007 09:32:08
 Re: Removing the Drawbar from a 39 B in reply to Proud B owner, 05-07-2007 06:40:14
Drawbar is held on by 2 pin plates and cap screws. First thing to do is PB Blaster it all and go away for day, repeat the lube at night and morning for a week or two if possible. Look at the front of the final drive housing (about a foot in front of the drawbar) - you will see a round blank hole and a threaded hole. The round hole accepts a pin on a plate, and the threaded hole accepts the cap screw that locks the plate and the drawbar to the housing (BTW this is where the hanges for your front drawbar for the plow go, using the same pin/plate combo) The drawbar attachmant is the same (as a matter of fact the ousings can be swapped side-to-side if the brakes are turned around). Then remove the bolt at the rear of the plate , and try to wiggle the pin out. Light taps on the plat to rotate it may help, but usually I end up tearing off the plate and having to resort to the torch and big pliers to get the pin out. Be sure to derust the hole and apply anitsieze to the pin before reassembly.
