D14 bogged down, stalled, won't start
Noel P
05-07-2007 04:51:06
Just bought a D14. I was mowing some pretty thick brush and the tractor bogged down and stalled. Now it will not start. Any suggestions?
John (MO)
05-07-2007 05:46:06
 Re: D14 bogged down, stalled, won't start in reply to Noel P, 05-07-2007 04:51:06
To run it needs fuel, air and spark. You will need to figure out which one it isn't getting. My guess would be fuel. Line plugged with gunk most likely. Could be at the tank, at the carb, or someplace in between. Pull a plug, see if it is wet, see if it is fireing. Plugs may have gotten fouled with oil and need cleaning. You could have had points, condenser or coil go bad, but I'm betting on fuel line being plugged. That`s what it is about 75% of the time.
Noel Putman
05-07-2007 06:35:48
 Re: D14 bogged down, stalled, won't start in reply to John (MO), 05-07-2007 05:46:06
Many thanks!
