Help!! AC160 Hydraulic Lift problems
Chet.ok
05-05-2007 13:11:21
I have an hydraulic lift that don't lift up. It would lift if ran at high RPM's, but won't hold if its idle down. It will not lift up while idling. Had water in Oil,drained oil and bleed the pump until clean oil came out.Still won't work.The Hydraulic pump is on outside of tractor.Could it have gone bad? The pump still pumps and this just started a few days ago. What should I Check first? Any ideas before tearing into tractor?
banjo
05-08-2007 20:32:59
 Re: Help!! AC160 Hydraulic Lift problems in reply to Chet.ok, 05-05-2007 13:11:21
if it is like the 170 , behind the seat is some valves . make sure they are not stuck open. should be able to push the valve back in if it is protruding out the cap.
Paul Baxter
05-07-2007 07:33:17
Something else. If the problem just started it could be the high pressure relief valve is stuck partially open and is bypassing fluid when it shouldn't. I am not sure where it is located. You need to get a shop manual and check.
Paul Baxter
05-07-2007 07:26:50
You probably need a new pump. Sounds like the pump is so worn it will only build up pressure at high RPM.
