WD adventure
Rendall Gray
05-05-2007 07:48:52
Went to Illinois to pick up Dad's old WD. Would not start, so used ether (probably a bad idea--lots of backfires.) Finally got it to run, but no power. Cleaned fuel bowl of large amt. of sandy looking material? Bowl gasket was shot and leaked badly. Couldn't find gasket and tried Permatex, but still leaked. Installed new bowl, replaced plugs, drained fuel tank, and cleaned and filled air filter.
Next day a old friend helped me get it started and it seemed to have more power, but not great. Started to work on moving in the wheels to transport while we let engine run. It died two or three times like you had shut off the ignition. No missing, just instant shut-down. Finally it died for good. Found out we had no spark to plugs. Cleaned points, replaced condenser, and used carburetor cleaner to clean oil out of mag. Not sure where oil was coming from.
Finally, got an old mechanic who knew mags to trouble shoot. By tracing spark through mag, we discovered rotor cap was not passing spark. Located new cap and put it back together. Fired right off. Why cap went bad after it had been running, we have no clue. It was a hot day, so may have been heat related.
Ran good enough to drive it over to a tire shop to get the wheels moved in and the fluid removed to lighten towing weight. Problem is it keeps lugging down while under power. Though we drained and flushed the carburetor bowl, I suspect some dirt getting in the jet. Also carburetor shaft is leaking. Also we may have blown an intake gasket as I thought I saw smoke come from that area on one of the backfires.
Have a timing question? When I replaced mag cap, I was told to line up the A or C mark on the fiber gear with the tooth mark on the metal gear while on #1 compression. The metal gear rotates anti-clockwise looking towards the front of the tractor, so I tried to line up the A mark with the tooth. Mag repairman told me the timing could be set with a timing light, but did not get particulars since we had no light. I have a light here, so are there timing marks on a pulley, and where would the reference mark be?
Also, can the timing be tweaked by moving the mag housing using the slot under the bottom bolt?
By the way, got tractor back to Arkansas with no problems. Had some hard pulls on the long grades, but didn't ever reach limit on the '95 Explorer V6. My GVW was 9750 lbs. which was 750 over the rated limit, but I had a new transmission so I figured it would hold up and it did.
vjd
05-05-2007 14:26:10
 Re: WD adventure in reply to Rendall Gray, 05-05-2007 07:48:52
Link
old
05-05-2007 09:36:25
Drop me an e-mail and I'll send you a mag manual for that type of mag. Some one did that for me so I pass it on when I get the chance to do so. That manual will help you a lot since it would take a lot of room here to expalin all the stuff the manual has in it.
Jerry Coulter
05-05-2007 08:40:14
The engine turns the impulse clockwise, so you should line the C mark up with the bevel on the little steel gear. Sounds like your fuel system needs a general cleaning.
