Hydraulic cylinder Model B
Eddie Jones
05-05-2007 07:02:07
I put the cultivator on my B-AC today but the cylinder won't pick it up. Is there something I need to check or is the cylinder too small?
Thanks, Eddie
Eddie Jones
05-05-2007 20:26:53
 Re: Hydraulic cylinder Model B in reply to Eddie Jones, 05-05-2007 07:02:07
Thanks guys, I got it a going.I just took it loose and kept working it back and forth. Hook it back up and it work.
Thanks again, Eddie
old
05-05-2007 09:31:30
As Texas says. PTO engaged and fluid level up to full as in you can't put a drop more into the tranny fill plug down under the clutch pedal area. Clutch has to be out/engaged also. The if it still doesn't work unhook the cylinder from the equipmant and make sure it will go out when you pull the lever. If it does then you may have it set up wrong or the thing is to heavy. Some of that type of stuff used 2 cylinders and some used just one
Texas Denny
05-05-2007 07:43:25
Fluid level in the transmission. PTO must be engaged.
