wd45 engine timing cover jamb-nut?
orange-1
05-04-2007 20:26:10
I discovered this while/after disassembling my wd45 engine. There is a bolt with a jamb-nut on the engine timing cover. This bolt appears to apply tension on the end of the cam? Is there a torque setting for this for reassembly??? Thanks,
JMS/MN
05-05-2007 07:37:41
 Re: wd45 engine timing cover jamb-nut? in reply to orange-1, 05-04-2007 20:26:10
It's purpose is as you describe. The I&T manual has instructions on adjusting it- my manual is in the shop, but the idea is to snug up the setscrew, then back it off ? distance, tighten jam nut. Memory says a half turn?
orange-1
05-05-2007 14:34:50
 Re: wd45 engine timing cover jamb-nut? in reply to JMS/MN, 05-05-2007 07:37:41
Thanks for your help. I will have to look in my I&T manual again. I must have overlooked it the first time.
JMS/MN
05-05-2007 19:16:13
 Re: wd45 engine timing cover jamb-nut? in reply to orange-1, 05-05-2007 14:34:50
I did check the manual later- it says 1/2 to 3/4 turn to back it off.
