WD45 hand clutch , Hey Old
MikeRW
05-02-2007 05:49:36
Old,
Yesterday on a message related to a D14 power director and shifting you had made a comment that you could use the WD45 hand clutch for shifting gears. Are you sure about this. I"ve had a 45 for about a year now and didn"t know that. Thought i"d better double check and ask before i gave it a try. Don"t want to damage anything. Thanks
Mike
Bob N.Y.
05-02-2007 16:32:12
 Re: WD45 hand clutch , Hey Old in reply to MikeRW, 05-02-2007 05:49:36
My brother had a WD and a WD45. I thought they shifted better with the hand clutch than the foot clutch.
MikeRW
05-02-2007 09:32:53
Thanks to All,
Great Info! Learn something every day.
old
05-02-2007 08:04:46
Well all I can tell you is what I have done with both the WD and WD45 I have and use on the farm. I shift gears in both of them all the time useing the hand clutch. I go from any gear I want to any other gear I wnat and never grind a gear. I do that a lot when brush hogging in tight places. Lets me go from forward to back um up with out stopping the hog which can be nice for some things like thorn trees which we have a lot of.
Butch (OH)
05-02-2007 07:49:54
I am not Old but I am old. You can shift the transmission using the hand clutch IF (read the if please) a number of conditions are met. 1.the clutch must be properly adjusted. 2. it must not have warped plates. 3. you must have the correct grade of oil in the housing. 4. you must shift briskly without pausing in between, which is a darn sight differant than ramming and jamming! 5. Dont try it until the transmission has warmed up some. So how can we shift gears without using the foot clutch? When you stop the motion of the tractor with the hand clutch the transmission is not turning, however because of drag in the hand clutch assembly the input side if the trans trys to start turning while in between of gears. If properly adjusted, and with warm oil of proper grade the drag is slight (and with absolutely no ramming or jamming) you simply shift it between gears without hesitation. The slight drag actualy helps to get it in the next gear by moving the gears into alignment. How can you know if your 45 is in the shape it needs to be in to try it? By simply checking for creep with the hand clutch out and in 3rd gear. If you must use the brakes to keep the tractor stopped on a level area while on grass, (not pavment) then you probably have too much drag to try shifting. You can always try it once just remember and slow shift will be a grinder no matter what.
CWL
05-02-2007 07:12:29
My two cents worth. I read on here a lot about how shifting with only the hand clutch is a bad thing. Some say you should always use the foot clutch for shifting. My personal experience with my WD is that when the tractor has been running in neutral I need to use the foot clutch to keep the gears from grinding. If I am just changing from a one gear to another with the tractor at a full stop I can use only the hand clutch and there is no grinding of gears. It doesn't make a difference on my tractor if the PTO is engaged or not. I shift from first gear to reverse often with a brush hog running with only the hand clutch and no problem. Same with when I use my box blade. I also use an overriding clutch on my pto just as an added safety measure. I know that you can stop with the hand clutch, but I had one occasion when I hit a hole hidden by some weeds. I was using both hands to keep from being thrown from the tractor and the foot clutch to try and stop. By the time I got the blades on the mower stopped it pushed me a couple of feet, and the brakes work very good. A couple of feet can be a very long distance some times! So now I use the overriding clutch for an added measure.
stu (ON)
05-02-2007 07:47:36
 Re: WD45 hand clutch , Hey Old in reply to CWL, 05-02-2007 07:12:29
I have to weigh in with CWL on this. When using a rear-mounted blade, to maintain control of the lift arms by keeping the hydraulic pump engaged , I shift gears with the hand clutch.
With the bush hog, the only way to back into a tight spot without waiting for the mower to stop to shift gears is to shift with the hand clutch. And the overriding clutch on the pto is a good idea, as I have been pushed into a fence by the bush hog when skidding on a muddy spot and my panic reaction was to push the foot clutch in.
My WD is the original version with the square-cut gears in the tranny. They are very sturdy, but can be a little stubborn to engage at the best of times. If you look at the drive train, the wet (hand) clutch disengages the driveline aft of the engine clutch. How can this be detrimental? Only if the wet clutch is set up with too little plate clearance when disengaged, or there is too much hydraulic coupling of the clutch plates. This does not seem to be the case if the proper viscosity of oil is used, it is warmed up a little and it is changed often enough to keep it from turning to molasses. This topic comes up regularly and I see that many fellows who use their WDs as I do are successful in shifting with the hand clutch.
stu
Butch(OH)
05-02-2007 07:54:38
 Re: WD45 hand clutch , Hey Old in reply to stu (ON), 05-02-2007 07:47:36
Sorry Stu you were posting that excellent reply as I was typing my post
