What model number
Greg Tollefson
04-30-2007 14:50:06
I have a FMZ6A3A magneto. On the box it says it is for L,LO.L6,L90 Monarch-Allis Chalmers. Is this the engine model # or the tractor model #.If it is the engine # does anyone know what Tractor # would be. Thanks
Glen in TX
05-01-2007 13:47:38
 Re: What model number in reply to Greg Tollefson, 04-30-2007 14:50:06
FMZ6A3A... FM= Fairbanks Morse brand, Z = model of magneto (Z is larger housing mag), 6 = 6 cylinders, A = Base mounting, 3 = Manufacturers application key number which is Allis Chalmers, A = could indicate some type of special variation of cap, lag angle, or position of ground switch or other variation.
It's a regular high tension 6 cylinder FM magneto, CW clockwise drive facing drive end of mag, 45 degree impulse lag angle, UA drive cup with 1/4" drive lugs, with base mounting.
Fits: Allis Chalmers early L,LO,L6,L90,& Monarch L. NOTE: Later L,LO,L6,& L90 used a SAE flange mount 45�, CW magneto.
Impulse could be changed for it to fit any engine or tractor using a CW drive base mount 6 cyld. mag but the rotation can't be changed to CCW.
Aaron SEIA
04-30-2007 17:24:43
If the box said Monarch, then it's probably for the old Monarch crawlers that AC bought back in the 20's or 30's.
Aaron SEIA
old
04-30-2007 15:20:05
How many cylinders is it for?? I.E. how many plug wires hook to it. A good number of those mags would fit a lot of engines. I know the one from a B will fit say a C, CA, WC, WD, WD45 plus a good number of farmalls also
Greg Tollefson
04-30-2007 15:41:10
 Re: What model number in reply to old, 04-30-2007 15:20:05
it is for a 6 cylinder motor
old
04-30-2007 17:49:58
 Re: What model number in reply to Greg Tollefson, 04-30-2007 15:41:10
Ok then I would have no idea on that one.
