C allis
Jim in NC
04-28-2007 07:07:46
Going to look at a 1949 C allis with a narrow front end later today. Neighbors have used allis tractors sine I was a kid, but i have had no real personal experience with them. Are there any particular things or wear points that I should check closely when I look at this machine? Thank you for your help.
russ1
05-02-2007 03:31:51
 Re: C allis in reply to Jim in NC, 04-28-2007 07:07:46
The front wheel shimmy can be cured by removing the front pedestal from the tractor and removing shims from the surface between it and the frame. You will likely need to remove only one to bring the bevel gear mesh into tolerance.
Jim in NC
05-02-2007 04:14:19
 Re: C allis in reply to russ1, 05-02-2007 03:31:51
Thanks for the suggestion. It came late yesterday so hopefully i will have a chance to spend some time workin' on it.
Robswc
04-30-2007 04:58:46
That front wheel shimmy just may be loose bearings, easy fix, run one of the two front wheels up on a scrap 2x4, remove the dust cap and tighten the bolt that holds the bearings in. I have a 6' mower on mine too, I like this set up, it is very good on gas.
Rob
Jim in NC
04-30-2007 05:34:32
 Re: C allis in reply to Robswc, 04-30-2007 04:58:46
Thanks for the tip. I hope it comes today. The grass is growing.
Texas Denny
04-28-2007 18:22:47
I think the weak point is the hydraulics. They were designed to lift cultivators that weren't that heavy and could be spring assisted. Putting a 3 point on one generally means either adding a second cylinder which substantially reduces lift speed or reducing the amount of vertical lift by changing length of the upper arm or point of connecting to lower arm. They are also light in the front so the front of the lower arms need to be mounted under the rear axle so the front wheels will stay on the ground when you use a 3 point shredder. These are the experiences I had with mine.
It only has 3 forward speeds. The third speed is a slow road gear and second works pretty good for a lot of work with low being good for harder going.
Jim in NC
04-28-2007 19:10:29
 Re: C allis in reply to Texas Denny, 04-28-2007 18:22:47
I went ahead and bought it. I needed another tractor like I needed another hole in my head, or something like that. It has almost new tires and a 6' belly mower. The tractor ran ok, but it has some carb problems as it would not idle properly, and looks like it has been taken care of. I saw no casting welds, and no blue or white smoke while running. Antifreeze and motor oil looked good. This is my first venture in the AC world. There is some but not much play in the steering. The owner said it would shimmy a little when on the road. It would be nice for it to have a 4 speed tranny, but it seemed to handle the mower fine and that will be its purpose. I have neighbors that are familiar with them in case I have trouble. I thought it was kind of a neat tractor. I hope it works out ok. It will be delivered in a few days. The owner offered to deliver it, so I took him up on it. Thanks for responding. Where can I find the rubber cover-boot that goes at the base of the gear shift lever?
Jim in NC
04-29-2007 12:05:58
 Re: C allis in reply to Jerry Coulter, 04-29-2007 11:19:57
The mower is lifted hydraulically through pulleys and a steel cable. It worked fine the times I tested it. I guess we'll see how it holds up. Thanks for the info about the boot.
Texas Denny
04-28-2007 21:30:56
 Re: C allis in reply to Jim in NC, 04-28-2007 19:10:29
I would suspect the idling could be corrected with a thorough cleaning of all the carb passages.
I like my C but I think I will sell it in a week or two. I had 17 tractors 3 weeks ago. Now I have 16. I am trying to sell one now to get to 15. I'd like to be at 10 or less. Don't have the time these things deserve.
