Snap coupler brush hog
tractormiallis
04-27-2007 19:12:41
Have the opportunity to possibly get an AC snap coupler brush hog that will work with my WD. I havent looked it over closely as to inspect the blades or gearbox, but the outside looked to be painted still. My question is, for those of you who have used one of them, how do the hydraulics work keeping the front of the brush hog up of the ground? Allis hydraulics are not like the new ones that stay in one position as with modern brush hogs.
Dave Anderson
04-28-2007 17:45:02
 Re: Snap coupler brush hog in reply to tractormiallis, 04-27-2007 19:12:41
On my 5' A-C bush hog, the toplink of the bush hog has an integral depth stop/chain hanger that keeps the same height setting. I know, I know a toplink generally is a three point hitch part, but A-C used them on bush hogs. It doesn't look like the standard three point hitch toplink, kinda like a flat adjuster with notches to hang a triangle shaped hook that connects to chains that go to the bottom of the s/c arms. A-C bush hogs have a built in over-running clutch near the rear of the rear u-joint, check to see that both spring-loaded pins are there and operating. Also check the rattle clutch mid way down the drive line. Both are frequently Booger welded items. In Md, I have seen these bush hogs bring as much as $800.00 at auction.
Sid
04-27-2007 19:32:21
Get some hydraulic cylinder blocks.
