WD governor
wdTom
04-27-2007 17:58:36
When I went to start my WD the other day it started Ok but would only idle. It turns out the srping on the front of the gorernor under the small cap held on by 4, 1/4" capscrews had come unhooked at the lower end. I put it back in it's hole, it snapped in, and it has been OK. I think I will try and order a new spring incase it is weak or stretched out. Has anyone had this problem? I see in the parts book they have 3 springs listed too. a 1400 rpm spring, the standard one, a 1600 rpm and a 1800 rpm spring, Anyone got any feed back on these?
JMS/MN
04-28-2007 05:54:46
 Re: WD governor in reply to wdTom, 04-27-2007 17:58:36
I believe they are for a WD, WD45, D17, in that order. Last two are both 226cid, but the extra hp comes from a higher governed speed.
