WD 45 clutch (gas)
John Testerman
04-27-2007 14:51:04
rebuilt engine had clutch rebuilt at local clutch shop now on reinstall distance between throwout bearing and fingers on clutch is about 1 inch cant figure a way to make work would like any guidance i can get
Sid
04-27-2007 19:37:14
 Re: WD 45 clutch (gas) in reply to John Testerman, 04-27-2007 14:51:04
Just a shot in the dark,check and see if foot pedal is locked in the disengaged.
kurt:ky
04-27-2007 19:07:10
Question is your clutch pedal hitting the stop or your foot rest. If the clutch pedal is hitting the foot rest the pedal is wore out along with the shaft. If it hitting the stop then you need to adjust the clutch rod.
old
04-27-2007 18:45:26
Don't know if this will help you or not. But when I switched engines on my WC Speed patrol I had the same sort of problem and found theres an adjustment on the rod that the throw out bearing is mounted. I adjusted that and it works just fine now. Bad thing was I pulled the engine back out because of it then found that adjustment
