D17 steering
flewster
04-26-2007 06:47:07
My D17 does not seem to steer very good. It turns alright to the left but not as sharply to the right. It is not hitting the stops but is there another adjustment?
Kip[UT]
04-27-2007 06:02:44
 Re: D17 steering in reply to flewster, 04-26-2007 06:47:07
When you adjust tierods make sure you add about a quater inch of toe in, if you point wheels traight ahead it will have tendency to shimmy.
BCnT
04-26-2007 07:23:57
i'm guessing you have a wide front end...sounds like tie rods wern't centered and one side is longer than the other.
flewster
04-26-2007 11:08:51
 Re: D17 steering in reply to BCnT, 04-26-2007 07:23:57
I will have to check that....how would I center them and check for centered tierods?
BCnT
04-26-2007 20:57:56
 Re: D17 steering in reply to flewster, 04-26-2007 11:08:51
make sure the center link [pitman arm] is dead center middle of tractor and both wheels pointing straight ahead...if not...loosen clamps on tie rod adjusters and get everything centered and tighten em up.
