Wiring Help
DaleMN
04-25-2007 19:18:17
I am trying to fix the wiring mess on my B allis. Complete new wires, switch and ammeter. The problem is that when the switch is in the first position it shows 0 charge when in the second position and the lights are on it shows 10 -14 charge. When in the third position is shows 0 charge. Would like to keep everything original. Thanks for any advice
steve(ill)
04-25-2007 20:46:08
 Re: Wiring Help in reply to DaleMN, 04-25-2007 19:18:17
well it sounds like a couple wires are off or not grounded on the light switch. there is a resistor on the side of the switch that the "F" wire from generator connects to in the first position and then to ground. this gives about a 3 amp charge. in the next position, you ground the F wire directly and get 10 amps. in the 2 or third position, you ground directly and turn the head light on at the same time. sounds like the resistor might be bad, or contacts in the switch, or not grounded terminal.
