rust in gas tank
Barry Adamson
04-24-2007 15:00:35
Has anyone had experience with liners, products or methods to deal with rust inside the gas tank on a Model B or similar vintage (1940) tractor?
Dick L
04-25-2007 12:32:18
 Users Of POR Products in reply to Barry Adamson, 04-24-2007 15:00:35
Might want to read
Dick L
04-25-2007 12:27:06
 Re: rust in gas tank in reply to Barry Adamson, 04-24-2007 15:00:35
I have had very good luck with the Eastwood tank sealer.
Barry Adamson
04-25-2007 07:33:22
Thanks Bob,
I'm a little unclear about having the tank "boiled out" at a shop. Is a solvent or other cleaner used to dislodge the rust? What prevents its return?
My tank is in need of exterior sanding, priming, & painting. I'd hate to put all that work into it without knowing the interior was sound.
Barry
BobOHIO
04-25-2007 07:22:31
Barry I used the POR tank liner on my 1946 Farmall. I wouldn't recommend it. I followed the instructions and after awhile it began to peel off and plug the sediment bowl with small silver flakes. To do over I would take the tank to a shop and have it boiled out and forget the liners. At least the liner made by POR didn't work for me.
Rod (NH)
04-24-2007 16:26:59
Hi Barry,
I've had excellent luck with an epoxy gas tank sealer (liner) from Caswell Plating. You might also want to consider adding a fuel bowl riser and low point drain to your tank.
third party image Rod
Barry Adamson
04-24-2007 16:48:00
 Re: rust in gas tank in reply to Rod (NH), 04-24-2007 16:26:59
Rod,
Thanks for your quick response. I'll look into both of those ideas.
Barry
