Help how to change oil
Pelle
04-24-2007 12:40:58
Dear friends!
Glad I found this page! I live in Sweden, hope its ok for me to write here, I just bought my first vintage tractor! A nice little Allis-Chalmers B, from the year 1939. Now, here is my question; How do I change oil in the gear/transmission box, and in the rear axle, and rear wheel transmission? I have changed oil in the motor, no problem, but were do I empty/fill new oil into gearbox and rear axel/rear wheel transmission? Or, maybe I dont have to change it at all, I dont know. So You guys, help me out here please.
Best Regards
Per Sweden
steve(ill)
04-24-2007 19:48:32
 Re: Help how to change oil in reply to Pelle , 04-24-2007 12:40:58
the little B has three plugs for the trans- bevel gear- hydraulics/pto. pull all three plugs and you will get about 7 liters of oil drained. put the plugs back in and fill thru the 1 inch pipe plug by your left foot. you can use a good grade of 20 wt oil, or better yet, use universal hydraulic- transmission fluid that says AGCO 821, CAT TO2, or JD spec. all are o.k.
----the only other lube is in the final drive pans setting inside the wheel areas. you need to take the half moon pan off each side while laying under the tractor. clean out the goo. reinstall and put a quart of 80-90 gear lube in each side. (same as a truck axle)
russ1
04-24-2007 13:56:38
Pelle.
Look under the transmission/rearend and you will see two drain plugs. Three if it has a PTO. Remove them and drain the transmission and rear end. They are one. You will see a large plug in the side of the transmission behind your left foot rest. Remove that and pour in the new oil. The manual says to use SAE 20W non-detergent motor oil.
