Allis B Orhcard converstion
the tractorlad
04-24-2007 12:22:33
Hi iam from the UK i am currently restoring an Allis Model B upon seeing some pictures of an orchard converstion i rather liked it and now want to convert mind as it will be unusual which i like can anyone e-mail me some pictures of one detailing rear wing moutings etc brake linkages and anything else that might be different
Thanks
Ben
MJ in the UK
04-25-2007 05:14:17
 Re: Allis B Orhcard converstion in reply to the tractorlad, 04-24-2007 12:22:33
Imight be able to help you were in the UK are you located. MJ
thetractorlad
04-26-2007 10:19:27
 Re: Allis B Orhcard converstion in reply to MJ in the UK, 04-25-2007 05:14:17
I Live in Worcestershire by a place called Kidderminster
MJ in the UK
04-27-2007 02:22:46
 Re: Allis B Orhcard converstion in reply to thetractorlad, 04-26-2007 10:19:27
Hi Ben I live on the Nottinghamshire and Lincolnshire border near Newark. I will get you some info and post it on this board. The Mid Shropshire Tractor Club are featuring Allis Chalmers tractors at there rally on Shrewsbury showground on June 1st and 2nd this year. MJ
tractorlad
04-27-2007 12:46:07
 Re: Allis B Orhcard converstion in reply to MJ in the UK, 04-27-2007 02:22:46
Thanks for looking out the information for I might take a visit to shrewsbury as it not far from me and also my neighbour is taking his Allis B I restored for him there
Ben
thetractorlad
04-25-2007 05:08:49
Thanks guys for the comments i think i will be having a go as it will be some different in this country my only problem might be getting some WD45 wings as i do like them on these
steve(ill)
04-24-2007 19:57:48
an IB or OB conversion out of a regular B is a good size job. I can give you some info and photos if you want. I have a IB industrial unit and i used it as an example to build the OB from a B. You can rotate the rear axle housings 90 degrees and thats a start. You need to remove the horseshoe front axle and "build" another straight axle about 2 inches thick and 2.65 inches high.--- for the rear end, you can use the normal B fenders or go with WD45 fenders like the IB uses. either way, you are building your own mounts.--- samae for the brake rods. now the lever points out the back instead of up the top, so you have to bend 1/2 inch rods in a half moon shape with C on each end to connect the pedals to the brake levers. You also need to decide if you are installing a pan seat, or a beench seat. either way, you need to "make" brackets, etc, etc. I can give you some photos to get you started, but its a lot of looking, thinking, planning and "modifying" to get things to fit, and also look correct.
[email protected]
ShepFL
04-24-2007 12:30:31
 Re: Allis B Orchard conversion in reply to the tractorlad, 04-24-2007 12:22:33
I would be interested in pics. Never seen anything like that.
ShepFL
04-24-2007 12:34:49
 Archive results in reply to ShepFL, 04-24-2007 12:30:31
Paste in your browser address line
Link
Link
HTH
