WD won't start with starter but starts by pulling
JimfromWA
04-23-2007 09:07:06
WD runs well, used to start real well but last 2 times I've had to pull it. The battery is charged and the starter turns the engine over easily.
I would normally jump in and start checking the normal things, but due to surgery I only have one arm for a while.
What is most likely cause?
Also, Does any one have any opinion on the integrated Allis Chalmers plow. I assume I would want a 3-14. What is the availability of them?
Tractormiallis
04-24-2007 17:22:43
 Re: WD won't start with starter but starts by pull in reply to JimfromWA, 04-23-2007 09:07:06
That plow you mention will either be a snap coupler or the older pick up plow that is not snap coupler. It is a 2 bottom 14 inch plow built for the WD. I have the old pick up 2-14 for my WD.
Glen in TX
04-24-2007 09:23:34
If it has a mag and you don't hear the impulse clicking when turning over to start the impulse spring is probably broke or impulse parts in mag worn or broke. I have springs and parts for those. No mag then check what others said like compression and points. Battery good? Cables large enough not the small auto cables. Good terminals and connections? Starter in good shape? Distributor advance not stuck working okay?
JimfromWA
04-23-2007 12:42:50
It's the stock 6 volt - Positive ground
Sid
04-23-2007 14:32:48
 Re: WD won't start with starter but starts by pull in reply to JimfromWA, 04-23-2007 12:42:50
Magneto or distributer? If Mag, and starter is spinning it good I suspect a compression problem. I would think that would rule out any amperage problems. If it has a distributer then I would suspect Old has the right idea. I had a problem with not enough amps and the tractor would start a lot of times just as I let go of the starter. A lot of times a tractor with low compression will start by pulling and will seem to run fine for awhile until compression gets too weak to even pull start.
old
04-23-2007 11:59:01
6 volt or 12 volt. You may have a problem with the starter pulling to many amps and because of it you don't have enough zap to fire the coil. Other things could be weak spark and it needs a tune up. Or maybe you have a clogged carb any of those thing can cause that type of problem
CENTAUR
04-23-2007 10:01:54
I would check the points first.Does this distributor have a vacuum chamber?If so consider replacing the primary (pig tail)also since the flexing greatly decreases the continuity. CENTAUR
