WD45 hydraulic question
Jeremy Conaway
04-22-2007 20:17:37
I have a "55 WD45 with a factory loader that has the original lift cylinders. The previous owner removed the trip bucket and had someone fabricate a very nice wide bucket which is set up fully hydraulic. The whole system runs off a Haldex model 10564 pump (http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200329710_200329710) which is driven off the fan belt. Overall they appeared to have done a good job. However, the pump they used is very low volume at 1.5 to 3.0 GPM. As hydraulic-dumb as I am, I realize AC used a low-volume high-pressure system on their older tractors, but doesn"t this setup sound too weak for such an application? It has a hard time lifting much of a load, and both the lifting and curling actions are very slow as well. Northern tool also offers a couple of other similar pumps that would be a drop in replacement other than the hose fitting size, namely the 10566 and 10567 which offer much more volume but lower pressure. Would either of these help with the speed and lifting capabilities of this loader if I retain the same cylinders? If so, would I have to replace the hydraulic lines with larger ones to accomodate the higher volume of fluid? Any help is much appreciated as it would be nice to have a better responding system when removing snow, etc...
Thanks, in advance.
Texas Denny
04-23-2007 09:06:01
 Re: WD45 hydraulic question in reply to Jeremy Conaway, 04-22-2007 20:17:37
Jeremy, sorry but I have questions rather than answers. First, what is the belt ratio on the pump - ie the diameter of the pulley on the pump to the diameter of the pulley on the crankshaft. If the diameters are equal, you could double the volume (lift rate) by putting a smaller pulley on the pump. I'd say the best ratio would be 2:1 (crankshaft pulley twice the diameter of the pulley on the pump). What is your current ratio?
Second, how is pressure limited in your system? Where is the pressure control valve? What pressure is the pressure relief set at? You may have the pressure relief valve set at 1000 psi which would make the system seem anemic.
And if the pressure is set near 3000#, is the fan belt slipping? Seems like a lot of work to accomplish with a fan belt. If the belt is not slipping, possibly a larger pump would help but realize that if you double the pump volume, your fan belt will have to handle double the tension. If you double the pressure and double the volume, you will have 4 times the tension on the belt.
I would think your situation can be improved but I would move slowly on the solution - making sure it will work before implementation.
1 - make sure the fan belt is not slipping.
2 - verify your pressure relief.
3 - determine the belt ratio.
The 66 pump has double the volume that you current pump has. That is a big jump. I wouldn't go any bigger than that. In fact, you may be able to get what you want out of the current pump.
The Allis hydraulic pressure is irrelevant in your case. It is 3000 psi or so and most other systems are around 2000 psi. Either is plenty - the lower pressure systems use bigger pumps and larger cylinders to accomplish the same work.
Jeremy Conaway
04-23-2007 11:48:46
 Re: WD45 hydraulic question in reply to Texas Denny, 04-23-2007 09:06:01
Thanks for the help, guys. Denny, I'll answer as many of your questions as I can, and respond to your other questions with some of my own.
The tractor is not in front of me, but if I remember correctly, the pully on the pump appears to be 4 to 6 inches in diameter (outside edges, not inside the groove). Would have to look at the crank pulley to see how large it is, but it should be stock.
I do not know how the pressure is limited in this system. It does have a 2-spool control valve; is that where you normally set the pressure limit? I don't know if the belt is slipping or not, but you never hear any squealing so maybe it's not. How else would I tell? As far as my statement about the pressure of the Allis hydro system, I do realize that is only relavent to whatever is hooked up to the factory pump. My question was how the factory cylinders on the front loader would respond to a higher-volume, lower-pressure pump. Do you guys have any idea what volume the original pump put out?
Thanks again!
Texas Denny
04-23-2007 12:48:12
 Re: WD45 hydraulic question in reply to Jeremy Conaway, 04-23-2007 11:48:46
If you have a 4 to 6" diameter pulley on the pump, the easiest way to increase speed of response would be to reduce the diameter of this pulley. Since your pump is rated at 4000 rpm, you would be able to get close to this at full throttle with a 3" pulley. If all you see in the system is the 2 spool control valve, you may not have a pressure relief valve. Or there may be one in the pump. I'll check the information at the web site that you gave us.
Regarding pulley slippage, if it is slipping with this load, it should get warm or even hot. When you go to a smaller pulley, the tendency to slip will increase.
If your loader is Allis Chalmers, you can use the Allis hydraulics for your bucket but you will loose independent hydraulics and have complications with your lift arms. If the loader is not Allis Chalmers, the cylinders may work but the seals may blow as most cylinders are not rated at the pressures that Allis uses.
I don't know what the volume of the Allis pump is.
That web site does not mention that the pump has a pressure relief valve.
Since the pump is rated at 4000 rpm, For maximum output, size the pulley with this formula;
Pulley diam = 1720/4000 X Crank pulley diameter
This formula might recommend a pulley smaller than 2.5 inches. As pulley diameter decreases, you'll increase the chance of slippage again. I'd not go smaller than 3".
So, it is sort of a dance. If you go to a smaller pulley, you increase tendency to slip but you increase the volume and speed of the cylinders. You could go to a bigger pump and use a larger diameter pulley which would reduce the tension on the belt.
I'd try the pulley trick first. It is a cheap test.
JMS/MN
04-23-2007 20:27:34
 Re: WD45 hydraulic question in reply to Texas Denny, 04-23-2007 12:48:12
FWIW- An AC dealer told me that when the first D17 tractors came out, they went to a showing in MPLS, and literally boo'd the factory reps when they said the pump volume was 7 gpm. They expected some improvement over the WD45.
Texas Denny
04-23-2007 20:38:11
 Re: WD45 hydraulic question in reply to JMS/MN, 04-23-2007 20:27:34
I guess the question is "how slow is slow?" If you double or quadruple the speed, is it still too slow? We don't really know what slow is. If 7 gpm is the standard pump, doubling the current would make it close to standard.
Jeremy Conaway
04-23-2007 13:41:23
I guess I'll just have to measure the pulley. My buddy was using it over the weekend so it's not at my house currently. It may only be 3 or 4 inches in diameter.
How would I recognize a pressure relief valve?
As for the factory pump, I do not want to go that route. In my opinion it would be crazy for me to do that since it's already set up on its own circuit and the OEM pump is dedicated to the 3-point (aftermarket) hitch and rear coupler.
As for pulley sizing, do you measure the outer rim, or down into the groove a 1/2 inch or so?
Texas Denny
04-23-2007 14:10:37
 Re: WD45 hydraulic question in reply to Jeremy Conaway, 04-23-2007 13:41:23
If the belt is flush with the top of the groove, you can measure the pulley OD at the outside diameter of the pulley. If the belt is down inside of the pulley, estimate the radius at the top of the belt and multiply this number by two. This will be close enough for choosing a pulley. The actual radius of a pulley is sightly below the top of the belt (near the position of the center of mass of the cords). Measure the crank pulley the same way.
I'm with you. If you have an independent system for the loader, stick with it. You can then use the loader and the three point at the same time.
For right now, I'd forget about the pressure relief valve. Some of these after market loader systems do not have one and they get by without it fine. If you start blowing hoses and seals, you'll need to add one.
One other thing. The pulley on the crankshaft of an Allis is designed for the large belts - I think 3/4". They will work with 1/2" belts but it reduces the effective diameter of the crankshaft pulley which slows down your pump. I'd use a pulley on the pump that matches the crank pulley. You want the crank pulley as large as possible because it allows a larger pulley on the pump and maximum energy transfer from the engine to the pump.
old
04-22-2007 20:35:29
Well its sort of like this. The more GPM you have the faster the work gets done. But the higher the pressure the more power you have so its a give/take thing. So if you lower your pressure it will lift les but if you increase the gpm the faster it will do it. So to get what you want you need more gprm and more pressure also. Or you can sort of think of it this way. GPM is HP and pressure is torque power. High HP but low torque still means little work done or high torque but low HP again little done so you need to equal them both out to really get the work done at a good speed
