TSX-719 Carb
Mark Streit
04-22-2007 08:09:16
Could anyone tell me what this fits? I thought it would fit a D-15 but it don't match up with the numbers in my data book and I sold the tractor in the mean time.
Glen in TX
04-22-2007 18:14:23
 Re: TSX-719 Carb in reply to Mark Streit, 04-22-2007 08:09:16
MS/Zenith book shows D 15 used TSX-815 or TSX-844 or Zenith universal replacement carb 12566.
Kent bof SWMO
04-22-2007 14:24:27
I've never heard of a "B" Gleaner. Is this a pull type combind?
Kent
Glen in TX
04-22-2007 18:10:56
 Re: TSX-719 Carb in reply to Kent bof SWMO, 04-22-2007 14:24:27
That's what the MS/Zenith book said and I wondered what a B was too? ASAE book The Grain Harvesters says Gleaner B was a self propelled combine made 1955-63 with 30" wide cylinder, 12 ft. header, rice special. Doesn't say anything about engine size. There was also a AB made 1953 only with 14 ft. header rice special.
Glen in TX
04-22-2007 12:34:53
Marvel Schebler book shows it to fit a B Gleaner and doesn't list it fitting any AC tractors. It may fit something else too but I didn't look thru the whole book just AC listings.
Mark Streit
04-24-2007 16:27:38
 Re: TSX-719 Carb in reply to Glen in TX, 04-22-2007 12:34:53
Glen,
Could you look to see what else this carb fits in your book. I thank you very much if you did this for me.
Glen in TX
04-24-2007 17:47:57
 Re: TSX-719 Carb in reply to Mark Streit, 04-24-2007 16:27:38
MS catalog doesn't show it to fit anything else so apparently the throttle linkage or something else made it particular to that application. Still found nothing on what engine was in B Gleaner either? It may fit others things so just have to try to or measure throttle bore and choke bore and see if throttle moves in right direction for it. The Zenith universal replacement 12566 fits many different engines but those come with a universal throttle and choke linkages that can be changed.
