WD45 wheel brgs
donwisc
04-18-2007 21:43:01
Well reconditioning of the old "45" continues, Had a noise in the left front wheel WFE. Found the inner brg was completely dry and rusted.
Questions
1. Are the WFE brgs the same as the brgs on a narrow front end. Some one was good enough to list the Timken numbers in the archives but did not differentiate.
2. Found what looks like a shim between the back of the grease seal and the spindle support. Is there supposed to be such a thing or maybe the last guy shimmed it up to allow for wear in the bearing.
JMS/MN
04-19-2007 07:01:36
 Re: WD45 wheel brgs in reply to donwisc, 04-18-2007 21:43:01
The wheels, hubs, bearings, etc. are the same for wide or narrow front. My original AC op manual also has parts illustrations, but no part numbers. First to go on the spindle is a retaining washer, then bearing spacer, hub seal, seal retainer, inner bearing cone. Your shim is likely that 'retaining washer'.
donwisc
04-19-2007 18:15:27
 Re: WD45 wheel brgs in reply to JMS/MN, 04-19-2007 07:01:36
Thanks JMS/MN Local brg house quoted 25.00 for cup and cone. Got them in stock.
