Voltage Regulator
Jim Hunter
04-17-2007 06:57:22
I have a 47 AC C, generator is shot, going to replace should I change the cutout to a voltage regulator?
DougInOR
04-22-2007 10:25:11
 Re: Voltage Regulator in reply to Jim Hunter, 04-17-2007 06:57:22
Do what Kent said. If you insist on changing to a voltage regulator, be aware that you may need to change the generator also - depending on what type it is.
LWD
04-21-2007 00:25:43
Link (take a look,its to good not to)
Kent of SWMO
04-18-2007 05:51:42
Put a internal regulated Delco 12 volt negative ground alternator, 3 wire NOT a 1 wire, and be done with it. If magneto ignition, the only wiring you will need to change other than wire the alternator correctly, is the way you connect the battery and swap the wires on the amp meter so it will read right. If battery ignition you will need to change to a 12 volt internal resistor coil with the negative side of the coil connected to the points. If you want and you have battery ignition is now that you have negative ground you could also install a Pertronix module in the distributor to do away with the point and condenser.
Kent
steve(ill)
04-17-2007 15:21:21
voltage regulator eliminates the resistor and wiring to the light switch. if thats bad, i might go to the voltage regulator. other than that, it dont hlep a lot. if you change to 12 volt generator, then upgrade to the regulator is necessary.
Bus Driver
04-17-2007 09:42:21
I would if it was mine.
