best mower to use
Chad B. Allis
04-16-2007 14:37:08
I have my 1950 WD running pretty well (still struggles a bit under load). I have a 5 acre pasture I need to mow. What would you recommend as the best general purpose mower, pullable/usable by the WD, for this job? Bush hog? Finish mower? Flail mower? How big a mower can the tractor handle? Pasture is a normal grass pasture. It's not cut for hay production, just grazing. I want to keep it mowed, but not like a golf course. Just well kept to keep weed growth to a minimum.
Thanks!
tim[in]
04-18-2007 13:22:30
 Re: best mower to use in reply to Chad B. Allis, 04-16-2007 14:37:08
i used a 5' bushhog pull type bush hog behind my wd before i got a 3 pt for my d 17.REMEMBER!!! you dont have a over running pto on it so unless you use one, when you need to stop tractor and mower blades both you need to push in clutch and use hand clutch . otherwise the bush hog will push you forward until it stops.i got quite good at hitting clutch and pushing in pto knob at the same time.be careful!!
Dave Anderson
04-17-2007 16:20:01
Chad- I have a 5' Allis -Chalmers pull type bush hog in good shape here in central MD for sale, if you are interested.
Chad B. Allis
04-18-2007 05:37:54
 Re: best mower to use in reply to Dave Anderson, 04-17-2007 16:20:01
Thanks, Dave. I"m in Central IL so a bit too far away, but I appreciate it.
jra
04-17-2007 04:24:52
I would get a good heavy duty five or six foot Bush Hog type mower, If your WD has had a three point hitch put on it I would get a three point one, if not a pull type would work. This type mower would do the job and would be good for mowing other stuff too, will cut small trees- 2 or 3" in diameter and would be less maintenance and would work on other brand tractors.
Sid
04-16-2007 19:55:08
For clipping pasture I prefer to use a sickle bar mower. It just seems to look and grow better. IMO
BCnT
04-16-2007 15:50:48
5 foot shredder should work just fine...drag type if you dont have hydraulics
