front spindle bearing
hammerfer
04-15-2007 16:06:53
Hi, I am having trouble locating the front spindle bearing for my 52 WD, it is very scalloped. Also looking for the upper and lower spindle seals and also just the seals for the hubs, as the bearings look new. Thanks for your time in helping me.
DARDAN
05-30-2007 22:13:44
 Re: front spindle bearing in reply to hammerfer, 04-15-2007 16:06:53
Hammerfer, If you mean the lower bearing on the vertical spindal,(not the wheel bearings), I believe it was actualy a barrel shaped taper roller bearing originaly. If not pitted or scored badly, it should be reuseable.
Texas Denny
04-15-2007 19:23:00
Under Tractor Parts of this site, I found "Wheel Bearing Kit - For models D-10, D-12, D-14, D-15 S\N up to 9001 W\5 bolt hub, D-17 S\N up to 42001 W\5 bolt hub, WD.This kit is for one wheel only. (Part No: WBKAC1)". They were $33. I have found them on Ebay for $25. If you go to a bearing supplier, you can probably do better than that.
