190 XT gasser proof meter
james e sulliva
04-15-2007 05:32:23
quick question, where does the proof cable attach to on the fords it's in the pump gear i'm looking around and can't find the hole to screw the fitting/cable back into...
thanks jimmy
A-C hayman
04-16-2007 17:46:13
 Re: 190 XT gasser proof meter in reply to james e sullivan, 04-15-2007 05:32:23
On my 190xt lpg, the cable attaches to the distributor. I think early gas models used this also.
jra
04-15-2007 05:58:11
It goes into the back of the Alternator. If there isn't a place for it, then someone has replaced your alternator with one that doesn't have a tac. drive on it. If it's a gas job, I'm not sure, but you could probable put an electric one on for less than the proper Alt. would cost, maybe.
james e sullivan
04-15-2007 16:03:56
 Re: 190 XT gasser proof meter in reply to jra, 04-15-2007 05:58:11
thanks for the info i'll check it out once the monsoon ends here in n.y. thanks jimmy
