1937 Allis Chalmers carb adjustment
Tractor Hank
04-13-2007 20:27:03
Just purchased a 1937 WC that had not been started for about a year. Put fresh gas in it and got it started, but it would only run for a short while on full choke. I took the zenith carburetor off and cleaned it as it was very dirty inside. I am sure one of the jets was just plugged. My question is since I don't have a book on this tractor, what would be good adjustment settings for the carburetor to start with. How many turns out on on the adjustment on the very bottom of the carb., and how many turns out on the adjusting screw on the side of the carb. Thanks for any help.
JMS/MN
04-13-2007 21:03:19
 Re: 1937 Allis Chalmers carb adjustment in reply to Tractor Hank , 04-13-2007 20:27:03
Generally, if you bottom out each screw and then back them out 1, 1 1/2 turns---no more than 2---they should run ok. Fine tune after that.
