Oil Types
Persian Paul
04-11-2007 19:44:19
Can someone please tell me the correct oil types/ viscocities for the hydralic rams,PTO rear end and finally the engine! I need to refill these unts!
Thanks,PP
steve(ill)
04-12-2007 18:47:05
 Re: Oil Types in reply to Persian Paul, 04-11-2007 19:44:19
hydraulics are universal trans-hydraulic fluid.--- motor is 30 wt or 10w40--- trans/ differential is 80-90 gear lube.
Persian Paul
04-12-2007 05:03:00
Forgot to list tractor type. I am working on WD"s and WC"s. One of my Allis books states SAE 20 weight for the pto/rams. Is this non-detergent? Also 80 weight gear lube for the differential. I can assume 30 weight for the engine for summer use.
old
04-12-2007 06:40:05
 Re: Oil Types in reply to Persian Paul, 04-12-2007 05:03:00
You can use hytran types of oil in the hyds on the WD and be ok. Years ago they didn't have hyd oils as such so they used motor oils instead but now days you can use the hytran types and be ok
Texas Denny
04-12-2007 06:06:51
The hydraulics require non-detergent oil. 30 weight in the engine is fine but multi viscosity will work as well - i.e. 10-40W. Because it is quite warm in TX, I use 20W50 in most of mine. Depends on your climate.
old
04-11-2007 20:02:49
On what tractor. In my C and WDand WD45 I use universal hyd tranny fluid in them but in others it can or will make a differance
