WD45 engine block swap
EddyA
04-09-2007 17:37:29
In need of info. Will a D17 226ci block work on a WD45 with all the internal parts of the WD45. If not what other block will work with the internal WD45 parts. Maybe WD ?
Aaron SEIA
04-10-2007 16:38:20
 Re: WD45 engine block swap in reply to EddyA, 04-09-2007 17:37:29
The 45 crank will not work in the 17 block. I might have a block in a week or so. Just bought a 45 for parts. When I get it home, I can dig in quick and see if you'd like, or you can try to find a WD or 45 block, or a complete 17 engine. The WD block would work, but you've got the side plate on the WD block and anyone looking at your tractor will wonder about the internals.
Aaron SEIA
chalmersbob
04-09-2007 18:24:06
same block, leave the guts in it, you'll have a little more hp.
Bob
EddyA
04-10-2007 09:07:09
 Re: WD45 engine block swap in reply to chalmersbob, 04-09-2007 18:24:06
Thanks Bob, I will need to place the WD45 parts in the D17 block do to I just had the crank ground and bought a piston and sleeve kit before the machine shop found way too many crackes in the webbing and one down the center main.
slowsmoke
04-10-2007 14:59:42
 Re: WD45 engine block swap in reply to EddyA, 04-10-2007 09:07:09
Not sure, but I don't think a '45' crank will work in the '17' block. mains are different.
